Went to use Donner and X/Y/Z axis move on the screen, but doesn’t move for ‘Frame’ or ‘Manual’
Usually this just means that one of the sensors got stuck.
You can turn off the machine fully, and e stop it for good measure.
Then slowly (and I do mean slowly) manually move the head towards the top left corner, when it hits the stop point, pull it back diagonally out about 2 inches.
You can then turn back on the machine and it should rehome and be okay. I will be up there in probably around an hour and can take a look then if not.
Perfect! Thank you!
