[Repaired mostly] Big Thunder down 2023/09/15
Hey all, big Thunder is down due to the hinge on the lid being broken. Please do not try to use it. It will only make it worse.
I will be picking up replacement bolts and nuts today, and should have it fixed in the afternoon.
FYI, thanks to Amelia, big thunder is back up and running.
Please note that the bed level looks like it might be slightly off though (not related to the lid fix), So if you’re trying to do fine etching, I would recommend using Donner instead.
