Is there a “proper / approved” method for removing the filament from the print head / nozzle when it seems to be stuck in there ?? Here’s the situation.
I’m pretty new to 3D printing. I went into the 3DP lab yesterday to test print something. I chose an open printer and noticed that it had a spool of the DMS-provided orange filament already installed and fed into the head / nozzle. I was going to swap that spool out for my own spool. I pressed down firmly on the latch (yes, I pressed down firmly and it moved down to the “free” position) and I pulled on the filament to remove it from the head / nozzle, but it wasn’t going to budge. I figure it had become embedded in the nozzle through being melted during the previous user’s print / use.
How do you change spools when the installed spool is already melted into the nozzle ?? What is the removal / purging procedure ?? Hoping this isn’t a dumb newb question.
