Hi all. I am looking for a temp monitoring solution for my hobbies. I’m looking for some input to see if anyone is happy with something like the Sensor Push or Inkbird temp data loggers. I had some experience with Inkbird…worked okay, but the bridge is fickle…and Inkbird interfaces tend to not be great. SensorPush is the same format as the Inkbird, but 4 times the cost. I am monitoring air temps for freezers, refrigerators, humidors, cheese cave and kegerator.
My requirement is something that can be checked remotely. I’m not opppsed to a bridge to bring them all together.
Thank you. Could you recommend a gateway? My initial Google fu pulled up a couple around $150. Not fully out of consideration, but a little more than I expected to get started.
Thank you for the recommendation. This looks like a very well made and supported product. But over $100 per sensor might be a little pricey for hobbyist consideration.
But I’m glad you pointed it out. If I get back into a commercial setting and want to monitor, this looks like an affordable solution for commercial consideration.
