Here is a starting place for you. I have cut black acrylic and found it to be no different than clear acrylic.
I have no way to read this to see what it says, but if you unzip it and then open it using RDWorks on one of the Thunders it will populate the settings and you can read them.
It’s actually a tiny little file but I can’t attach an .rld file on Talk. I can, however, attach a zip file!
125 acrylic.rld.zip (4.9 KB)
Of course, you will have to tweak these settings. I recommend cutting something small - like a one inch square - to test the settings.
In this file there are probably three different colored vectors:
Red - this is a vector but it’s a marking not a full depth cut
Green - full depth cut (usually interior vectors)
Blue - full depth cut (usually exterior vectors - sequenced as the final operation)
Assuming you’re cutting (not raster engraving) - definitely leave the protective film on until after the cut.
