Dear all,
I am considering a benchtop mill for my lab.
Use case:
-prototyping (precision work can be sent out)
-primarily plastics and aluminium
-accuracy within a few thousandths is sufficient
-largest pieces would probably be bulkhead mount cutouts in face plates for custom 19" rack-mount units (~19"x8")
-low duty cycle (used a few times a week)
-robust/low maintenance
-‘drill press’ function would probably be used most often.
-cnc not necessary
-1/2" chuck is necessary
I would prefer not having a lathe combo, primarily due to safety concerns.
Ideally, the mill would use metric units
220V power is possible, I’d need to have it installed.
Does anyone have experience with mills which would fit this need? There are many options online, few from sources I’ve heard of previously.
Thank you for your expertise,
David
