I am a newbie so there is probably an easy answer to this. I went in right after lunch to use the Dynatorch and the computer was non-responsive. The screen had power but no signal from the computer. Cycled the monitor a couple of times. So, the computer seems to be set up to thwart any attempt to reset or reboot. And the power feed is 4’ behind the large oven. What am I expected to do?
So the monitor cable has been known to be loose before, so check that first.
All else fails the lid on the box on the bottom of the cart can be opened and you can reset the computer via the usual means. There are 4 screws that align the lid that are generally loose enough you should be able to lift it right off.
-Jim
I will try that next time i am in.
