does anyone have Americium from the old smoke detectors or another Alpha Source?
I have some sources but Iāll need to locate them as they are stored awayā¦somewhere. If I can put my hands on them quickly, Iāll let you know.
If anyone else has a hookup, please give a shout, itās possible mine are tricky to get to up in the attic!
I have an NRO Staticmaster (1U400) source with a certificate that you are welcome to. https://www.statictek.com/shop/staticmaster-1u400/
Looking at the price Iām glad it was given to me. I canāt make it to DMS before tomorrow.
Russell Ward
Are you sure didnāt mean āMuricium?
hello sir, Iām not sure what this is, but im looking for small radioactive sources esp Alpha.
It is āmeasuring only 1.02ā³ x .93ā³ x .24ā³ thick.ā and is an alpha emitter.
Model P-2042 Specifications
- ISOTOPE: Polonium-210
- MATERIAL: Stainless steel housing, aluminum grid
- EMISSION: Alpha
- ACTIVITY: 500 ĀµCi
- Weight: 0.4 oz. (11.3g)
- OPTIMUM RANGE: 0.5ā³ to 1.5ā³
Russell Ward
Thank you sir, I dont really know what that is, some kind of ionizer or is it like a discrete part for a smoke detector? Thank you for your kind donation!
If you go to the website https://www.statictek.com/shop/staticmaster-1u400/ they have the complete specs. This is a picture of the item. It is used as an ionizer that is used to remove static electricity in precision lab scales and such.
It is 1" square and 1/4" thick - smaller than the picture.
Russell Ward
Problem with the polonium-210 staticmasters is their very short half-life of less than a year.
When was this unit manufactured?
I have had it for 2 or 3 years. I donāt see any date on it or the paper work with it. It may be weak because it caused the paper to turn brown in one spot but it didnāt turn the paper brown when I put it in its box next to a different spot on the paper the last time I put it in the box a couple of years ago.
Russell Ward
Polonium-210 has a half-life of approx 138 days.
Assuming best case of 2 years thatās a little over 5 half lives, which would make it at a tad over 3% of the original source remaining.
Theyāre still cool pieces of gear to show household uses of radioactive materials.
So whatās interesting about this source is it lists a stainless housing with an aluminum grid window.
One alpha particle interacts with aluminum to transmute to one P-30 atom and release a free neutron. I would normally expect this to use a thin gold window or something else.
From the description on the website -
Note on Ion Source
All NRD ion sources are encapsulated in precious metals by means of a patented process. This results in a static eliminator which resists oxidation, solvents, heat, cold and vibration.
This has a precious metal (gold?) coating. It sounds like it maybe for other reasons, or not.
Russell Ward
While I see @Josh_Melnick as a consummate professional and always concerned about safety, the request and reference to smoke detectors brings to mind the Radioactive Boy Scout.
And A young Sheldon Cooper.
