@Team_Blacksmithing It’s been a minute since I’ve been in, have the propane forges gotten the sign off to be ok using indoors? If so is there additional training that needs to be done/information that needs to be known?
Yes the propane forges are clear to use indoors under the vent hoods. If you decide to forge inside make sure you turn the fan switch on the wall next to the other door in the blacksmith room. I alway check to make sure there is air flow and if so then I start the forge up! If you have more questions let us know.
Awesome! Glad to hear it. Thanks much!
Checking it out, that switch doesn’t currently turn the fan on.
The fan for that vent is on the roof so you won’t hear it. You have to put your hand near the opening to feel a draft if so it’s on.
