Hello Dallas MS 3D Fab forum,
Have been working with the PolyPrint
machines for years with good result.
Today work is on a light object lit
by RGB LEDs. Short video of the object
shows the object at about a third of
the intended height.
The construction of the light object
shown in the video uses .25 inch
clear acrylic tube and IPS Weld-On 16 Acrylic
Plastic Cement
https://www.amazon.com/dp/B00R5NYM7M?psc=1&ref=ppx_yo2ov_dt_b_product_details
as adhesive. (Super glue won’t
work because it glazes the clear tube.)
This process is very time intensive
because the IPS Weld-on wants to work
with two flat pieces clamped together.
To get a bond between two tubes laid
in random pattern requires that the
objects, after a drop of IPS is applied
be left unmoved for about 4 or 5 hours.
This process must be repeated for
each tube. (Better way?)
A 3D model of the object was done.
Several attempts to print the object
have been made with the PolyPrinter
with not even limited success.
Perhaps the object could be printed
with the resin printer.
Three questions please:
Does it seem possible that the
light object could be printed
with the resin printer? -
Is there a resin which prints as
transparent (not translucent) as
the clear acrylic tubes? Or even
close? -
For other PolyPrintable models
prints were made successfully
with what is advertised as clear
or transparent ABS filament.
- Gizmo Dorks 1.75mm ABS Filament 1kg / 2.2lb for 3D Printers, Transparent
- BUMAT ABS 3D Printer Filament, 1.75mm (Clear), 1kg Spool (2.2lbs), Guaranteed Fresh,
Dimensional Accuracy +/- 0.02mm, Tangle-Free, Fits Most FDM Printers
The models made with the filaments are translucent, but not transparent.
Photo of model printed with Gizmo Dorks 1.75mm ABS:
Is there a filament that can be used in the PolyPrinter,
or other MakerSpace 3d Fab lab machine, that is clear or transparent,
or even more transparent than the model printed with
the Gizmo Dorks?
Thanks.
Allen Pitts
