Great first class last night! Very instructive. The powdercoating I did after the class came out great. Well, maybe not great, but certainly adequate. I’ll do better next time getting the powder thickness more consistent. Those inside corners are tough.
Max came by as my work was in the oven and noted that there are (or should be) some different tips for the powder gun that will allow a more focused spray rather than the large diffuser tip. We might want to think about (a) getting some more of those, as they will surely disappear over time and (b) maybe putting them in the drawers on the cart next to the oven or those plastic drawers with some labeling for which tip does what. This powdercoating setup is a splendid resource to add to DMS.
He also noted that the jars from Prismatic thread right onto the gun – that’s a useful tip for others that maybe should go into the training. My powder came via Amazon and was in plastic bags, but maybe if you order from somewhere else (or in a different quantity?), then they come in jars? That would help cut down on some of the mess and time cleaning up for other users.
I kinda wonder if shooting some water mist on the walls of the spray booth would make it easier to clean up after by putting a little barrier between the powder and the metal. Anything that could make cleanup easier – and clean up is clearly key in a shared space – would be welcome.
