After pierce I saw the tool height decreasing until it collided with the part. I did not see any warping in the metal.
After cleaning the shield and checking the spade connection on the sensor, I used the “Ohmic sensor” light on the control software and a wire to debug. It lit when the shield was connected to the slat.Before it started the arc for the second path it threw an error; the sensor was lit but the torch wasn’t touching anything. When I removed the shield I noticed a buildup of slag on the aperture of the shield, which was causing the shield to make contact with the nozzle. I cleaned it off but it was back again in one cut!
Stuff:
- I used the shield and swirl ring that was on the machine
- I used my own nozzle and electrode\
- I tried different cut heights from 0.06" to 0.066"
- I left the pierce height at default 0.110" (I think)
- I increased the time delay from initial > cut height 0.0s to 0.5s
- I decreased the feed rate from 190 ipm to 172 ipm
- The ohmic sensor light worked fine once I cleaned the buildup
- 65A nozzle, 10 gauge mild steel, other settings at library default
When I turned off the THC it worked fine.
