I’d like to generate a couple trough parabolic reflectors for testing a steam generation process. I’m envisioning a 1’ x 2’ pieces of plywood with a parabolic cut in it then a reflective sheet of aluminum pressed into the curve, with an ashed (blackened in a way it can handle 500c heat) aluminum pipe down the fulcrum.
Is there such a pattern already in existence?
