I came in to prep four screens for coating with emulsion, but there is less than a fingers worth in the sprayer. I’m not sure there is enough to scrub four. There is certainly not enough to clean four after printing. I don’t know if we have more stored somewhere or if it needs ordered
Do you need Bean E Doo or Strip E Doo? It sounds like you might be trying to use the wrong product if you are reclaiming screens and using Bean E Doo.
Bean E Doo is to remove/clean up Plastisol ink, and is usually a clear yellowy color.
Strip E Doo is to remove emulsion, and is a milky white color.
In any case, I will be in Monday evening and will refill the bottles as needed.
I was using it to degrease before applying emulsion.
I wanted to print some shirts, but there wasn’t enough to clean up afterwards.
