My interest is essentially RV with the potential to become a primary residence many years down the road. Land ownership is still possible with such an arrangement but not a primary goal. As such, portability is important.
The infrastructure for off grid is an interesting challenge - and in fact strikes me as the primary challenge in such an effort. Power can be somewhat independent (so long as you can live within limits), but water, climate control, sewer, and food make Independence of supply lines and/or connections to existing infrastructure more difficult.
Power demands escalate quickly. LED lighting takes watts. Laptops consume low tens of watts. TV’s (suitable for a small space) consume high tens of watts. Kitchen appliances take hundreds of watts. AC takes a kilowatt as does any kind of electric heat.
I’d really like to do solar power with a li-ion battery bank, but the amount of both required to run AC or any kind of heating demands for long would be prohibitive - and this thing needs to be reasonably portable. At ~$500/kWH for Li-Ion with decent power-output capabilities I’d need something like a $4000 bank just to be able to run a small AC unit overnight. I haven’t even calculated how many faceplate watts of solar it would take to recharge said bank in a day - suspect it would be far more than I can reasonably carry and deploy.
Solar panels have seen a nearly 10-fold reduction in price since I first looked at them roughly 7 years ago, but the rest of the system components (inverters, charge controllers, wiring, batteries) haven’t seen such drastic price drops. 18650 Li-ion cells can be had as cheap as ~$0.50/W-H and may get cheaper.
As such, any solar or battery bank I enact will likely just be sufficient for the smaller loads. I expect to utilize propane for the big heat demand (furnace, cooking) items as well as for a generator to handle the big loads such as kitchen appliances and AC.
The water situation is also interesting. One can only carry so much water in a given volume (I gather that 60 gallons can suffice for a couple on a weekend trip), but there’s also the problem of blackwater. I hear that composting toilets have come a long way - which will leave you with just greywater which is not as difficult to dispose of - but I’m not familiar enough with them to say they’re a good plan. The more adventurous could capture rainwater from the roof and treat/filter it into drinking water.
