Do we have a nut splitter tool at the space? I ran into some trouble yesterday trying to get a rusted nut off a sway bar end link, and ended up struggling to grind it off with a cutoff wheel. After more research, it seems like a nut splitter tool might have been the easier route?
We do have, or did have, to best I recall, an induction heater designed for fastener removal. Or maybe I just thought it would be nice…
Anyway, big brand name one - Bolt Buster (because Nut Buster wasn’t deemed “marketable”, I guess?)
I thought one was floating around the 'Space in recent history.
Sway bar link nuts are often nylocks or similar and with the aid of a pry-bar and a pneumatic impact gun - cutting of the hardware is unnecessary.
Simple ball joint pinch bolts are fairly easy - no smoke wrench needed. (if you happen to have a later model Audi where the brainless engineered a long ass steel bolt anchoring into an aluminum threaded hole for the upper two control arms - then yes, there is a VERY high likelihood of snapping this bolt off midway.
Went back on Saturday morning to take off the other end link. Used the induction heater, some Kroil, Vice grips, and the M12 ratchet tool. Got it off in 15 minutes. Couldn’t Get the ball joint pinch bolt to budge though.
