We just step tested the new emulsion last week with multiple timings, and set it at :54 as it produced the best results. We first tested at 20, 40, 60, and 80 seconds, and are still coating both sides as per normal procedure.
In our testing going above 60 seconds starts over exposing, and 80 seconds (1:20) makes it extremely difficult to wash out the stencil to reclaim the screen.
That was the correct timing for the old emulsion, which was fairly old and losing its sensitivity. The new pink emulsion is freshly mixed/sensitized, and is much faster than the old blue mix.
@ozindfw
We exposed and used two screens with the :54 settings successfully for the 4 color classes this past weekend, so I’m not sure where the problems are coming from.
- Try giving the emulsion a good stir before use, it’s possible it separates a bit since this new batch isn’t a premixed/presensitized formulation like the old blue mix was.
- Use cold, not hot water to rinse out the screen after exposure. Hot water can blast out even properly exposed emulsion before it has dried out for the first time after exposure.
- It’s possible that the screen wasn’t properly degreased and therefore the emulsion won’t stick properly.
