Hi so I got a 5-month-old puppy earlier this week and he is still teething. He got to the table with my 3D printer and chewed through some of the small cables does anybody here have experience and is able to fix it? I will pay you
How is it terminated? Were both ends terminated the same? Is the other end intact for reference?
It’s been chewed through a bit so basically roughly cut my best guess as to what needs to be done is a cable added and soldered to bridge them back together. It’s a couple of cables
Should be simple enough; some solder and heat shrink, maybe some replacement PET sleeving depending on the nature of the cable.
When are you around the space?
I can be there Tuesday anytime after 1pm or I’ll be there Thursday too
I’m getting volunteers together for a thing on Tuesday, so tuesday late afternoon or evening will probably work best. We can play by ear, as we currently don’t have a start time for what we need to do set
Awesome thanks!
I should be in around 7
I’ll be done with my wood class around then
I’m about 30min behind; have to pickup some supplies on my way in
No worries I’ll be doing some work in the space and I’ll meet you around the work area by the 3D printers when you’re ready
