My memory isn’t as good as it used to be. Not sure why I was thinking alcohol but yea I remember acetone now that you mention it.
Got the harbor Freight version because its so cheap. Ended up having to order a new support rather then use the one from the parts car. Dear god this is taking forever to do though, so many welds to cut through
Update for you all followed by a question.
After many long hours of drilling and banging away, I finally managed to get the front end removed.
and the test fit looks great
Now I need to get a spot welder.
As I’m unable to get the car in its current shape up to the makerspace, is there any way I could check out the spot welder for a few hours?
https://dallasmakerspace.org/wiki/Rules_and_Policies#Code_of_Conduct
Section 4, 5th subpoint:
Tools/resources must stay on the premises so that other members may use them.[3]
Note 3:
Removing tools/resources from the space without authorization from an Officer or member of the Board of Directors is theft.
So…
Sounds like that’d require an OK from an officer or a member of the board, although since it’s on loan, I don’t know if the owner can OK it. I think it’s owned by @aallman72
We no longer allow any kind of checking out or loaning of DMS tools (as that is not practical given number of members). Does anywhere rent spot welders? Other options would be to find someone with a spot welder that would lend it to you or find someone who has a trailer and would help you move the car to DMS.
Uhaul, Penske and a few other rental places rent car trailers
The HFT spot welder the 'Space has is a 240V unit, which, though I could be wrong, I doubt you have access to at the work location.
The 120V unit is only $170.
That’s roughly 3.5x the cost of renting a tow dolly ($45x3.78~170), and 3x the nominal cost of renting a tandem axle trailer($55x3.10~170) from U-Haul, assuming you have a vehicle that can do the tow (and that U-Haul or other company will let you use).
I have no point other than helping shovel information into your decision stream (and to point out that even if you fenagled borrowing the spot welder from the 'Space, it might not be so easy to use. 240V outlets and extension cords aren’t like those for 120).
Yeah, been getting real friendly with the local uhaul guys this past 2 months. Starting to hurt the bank lol. But that sadly may once again be my best bet. Sadly, didnt find spot welders for rent in the area when i checked earlier. And the price is a bit too steep for how little I will use one. Thanks though everyone. I guess I’ll try and get the car up to the space at some point and just spend the day/night getting it running there lol
That 220 spot welder is pretty low end. I wouldn’t trust it for a car. Play with it at the space with some scrap just to test it.
