I am looking for help with my smaller MIG set up. WELD-PAK 90i MIG
I still need the argon carbon dioxide and MIG wire and practice metal.
Also if anyone has a book they could suggest for MIG TIG and STICK.
Try here:
https://www.esabna.com/us/en/education/index.cfm
https://weldingweb.com/vbb/
https://www.weldingtipsandtricks.com/ <<<<<<<<<<<<<<<<
https://weld.com <<<<<<<<<<<<<<<<
Articles – HTP America - USA Weld
https://weldingweb.com/vbb/threads/30845-Mig-like-Tig
https://americantorchtip.com/blog/top-5-causes-of-bird-nesting-and-how-to-fix-them/ *
https://weldinginfocenter.com/dcep-vs-dcen/
You will have to dig to find training info in the major manufactures sites.
PrinciplesSMAW.pdf (572.2 KB)
Best,
Jim
For argon/c02 buy the biggest bottle you can afford. Most welding supply houses run a bottle racket where they price gouge on bottles and don’t exchange any bottles except ones with their stickers. Airgas is particularly bad. I would buy a bottle on Facebook marketplace and then exchange it at ace or Home Depot. You might need to pay for pressure testing but it’s still cheaper than the $650 they will charge you for a new bottle.
As for wire, .035 is standard. .024 is light. Flux core is for a no gas mig setup. Solid core is for a gas setup. That little welder can probably only handle a 5-10 lbs spool. I’ve never used any wire that was terrible. I usually use Lincoln or Hobart wire bought at northern tool. Cheaper wire can be found online. I like cyberweld for equipment online. Amazon also works
CeramicCap,
I see that I misunderstood the question and I apologize. Take a look at the DMS Talk for MIG classes. None are posted at this time but if you post a request I am sure that one of the instructors will respond. If they do not, I would be available for a one on one at no cost between 1/19 and 1/21. It would last 2-3 hours.
Best,
Jim
