Need help with digilent embedded system project
I have a project i think might be good for makerspace. it involves makeing a web base oscilloscope and programming system that can be accessed via temporary Dallas makerspace log in accounts. I am looking to run this idea past the current electronics chair and denzuko.
Digilent waveforms is installed. ardunio ide as well… VNC should be installed as well. Scope should be calibrated soon but i responding reasonably. Unit is installed on raspberry pi 4… Tinkerboard installed failed. Same image also has digilent agent installed thus cold use a openscope… for web access.
Long story short the project is to make a box and set of boxes to program arduinos or other microprocessors then electrically record the result of the micro processor in circuit via the web.
Anyone know David Guill handle here… Dallas member that did this
http://likemagicappears.com/projects/raspberry-pi-cluster/
