Hi Woodshop Makers,
I am not trained on the MultiCam. Unfortunately, my project cannot be broken up into a small enough format to work on anything other than the MultiCam since several of the pieces are too large.
I am building 2 F/A18-C Hornet Flight Simulators, the framing of each requires 4 sheets of 3/4" MDF and 3 sheets of 1/4" plywood.
I have all the .DXF files ready to go but I have no experience setting up tool paths or with using CNC machines. I am happy to compensate you for your time or make a woodshop donation if you can help.
Any help or suggestions would be appreciated.
-Nik S.
