Hey everyone,
I came in the other morning to do my first solo jobs on the MultiCam and wanted to provide some feedback based on that experience. After running a successful test piece, I went ahead with the first tool path. Everything was working as expected, except I was a few mm shy of cutting through the bottom of the material. I tried changing my material depth in Vcarve and material thickness was verified again. The pendant was displaying “max material depth”, even though it wasn’t cutting all the way through (3/4" plywood). I triple checked my top and bottom depths were set correctly, but the machine just wouldn’t go any deeper. Is there a machine setting that inhibits the router from cutting more than the measured top and bottom depth? Maybe there was an issue with the bottom depth measurement?
Then I started having connection issues with the pendant. When I would try to run additional toolpaths, the pendant would take minutes to see the toolpaths load on the screen. Then they eventually stopped showing up. I did some searching on previous threads, and it sounds like the connection is a known issue (Mitch posted a video on a potential fix). I was able to finally get it working again after rebooting the computer and machine 3 times each.
Finally, I know @SWA had mentioned at one point the gantry has been known to shoot towards the back of the table randomly. This happened to me once, and I have NO idea what caused it to do so.
All in all, I was able to complete the job it just took a while to get the everything to cooperate. If anyone has any thoughts on how to avoid these issues in the future please share.
Thanks
