The name is a bit misleading, or maybe a lot misleading but this IS an electronics class. The class is designed for anyone with little to no knowledge about electronics design. The premise is this: We will go step by step from idea to hardware in your hand, pretty simple right?
Our first project will be a custom micro-controller development board (custom Arduino clone). We will start with a single part number and learn the basics of using a datasheet and how to find the relevant information for our application. We will use EAGLE to design the schematic and PCB, we will order boards from a fab, parts from a distributor, and assemble and test them in class.
If you want to sign up for this class you can do so on Eventbrite, or if you want more information you can check out the hackaday.io project page. There is a $10 fee per class that will be used for food and beverages during our 6 hour class as well as go towards the purchase of our hardware when the time comes.
Let me know if you have any other questions about the class(es) and I look forward to seeing you there!
