Last night and into this morning I was working on a project in the shop.
I needed to do some milling on the part, so I went to the Bridgeport. I could not get the collet to work - it sounded like it never engaged.
So I moved over to the other mill. That one worked long enough to get my first mill into the machine, but then would not let me remove it.
Might be an air pressure issue, although the regulator on the machine was showing 80 psi.
Sorry for the delay in reporting. I forgot to do so before I left the space.
