For those interested in melting metal to build something, I thought I would offer some rule of thumbs to help out with knowledge around MIG welding and setting up the machine.
This is just just one way to get some voltage and wire feed settings if you dont have any idea where to start.
Let’s take 1/8" carbon steel for example:
1.) 1/8" inch = .125
2.) one amp per .001" = 125 amps
3.) if you are using .035" wire, use 1.6 to figure the wire speed for .125 metal.
4.) 125 x 1.6 = 200 inches per minute.
That gives you a starting point in setting up the machine.
Now, just adjust voltage to get a good smooth bacon frying sound.
(assuming you are using MIG with 75/25 gas)
Hope it helps for those folks new to a MIG.
Also, our Millermatic 252 has Auto-Gun Detect.
