The A/C in the metal shop will never work enough for the metal shop to be comfortable in the summer months.
What can be done about this? Could we get some sort of A/C unit to supplement? Or re-balance the air flow? Does it share the A/C with woodshop? Wasn’t that clogged?
It seems we have a problem with A/C in other places as well. We have fans in our main hallway. Alas, this might need to be split into another topic.
Is there a solution for this? I really hate to tell members that I’m not going to be teaching because that part of the building isn’t habitable for 5 months of the year.
I dont have any ideas unless metal shop members want to replace wood shops filters every week
Perhaps a compromise can be reached and wood and metal shop can alternate changing the wood shop filters, such that it happens on a weekly basis.
Woodshop is currently in charge of changing it once a month, to supplement our existing filter changer. The coils are frozen up from one missed change from woodshop. Whatever works just needs to be done on a schedule.
There are 0 intakes to RTU 9 (woodshop - metal shop) in the metal shop. Metal dust does not get in the unit. It is all wood dust.
Yay! It’s not us. You heard it here first.
BTW I’ll go change them today since the vendor wouldn’t do it (since it was trapped in ice!). That should provide a week of ok cooling, someone will need to go up next week though if you want it to continue.
@Team_Woodshop can you please let us know the schedule you have to replace the filters? If Metal shop is willing to help I would jump on that.
They looked to have been replaced already a couple of days ago? Not sure.
Went up and unclogged a couple of drains.
@Team_Science let me know if you want a sample of this one day
Don’t poke it…it may poke back.
I’m hesitant to move the returns. This will force the dust out of wood shop to build up on surfaces in other rooms and plug up heatsinks and cooling fans in computers like laser, which suffered just from leaving the wood shop doors open on hot days.
I have suggested this in the past. In my opinion it should be done. There will need to be a chase from one room to the next. It would need to be sealed as well to not gather dust between walls.
Another question is where will these committees be located in the fall? Does it make sense to do more than up the schedule of filter changes until then?
Summer … yes it makes sense IF it is something that doesn’t cost a lot and can be done in a weekend
We used to do it on the 1st and 15th of every month. Now we only do it on the 15th. I bought a box of filter a few weeks ago. They should be by the woodshop annex if needed.
Id have to look at how long the runs are & the diameter which I think they are 2 24” returns. Its been a while since I have priced duct work.
I’m up for scheduling a work day and gathering volunteers. It’s only getting worse now that powder coating has become a reality for many.
