With the CNC router we are allowing aluminum but nothing ferrous. And it has to be done in a certain way with no coolant. Just the air cooler and specified bits. There are process and procedures that need to be followed.
When someone wants comes in with a sheet of metal on the table saw what is the process and procedures? The table saw does not have a lubrication system. You definitely don’t want sparks being thrown into the dust collector or any hot metal pieces into the saw dust. Should we throw a metal chop saw wheel and let people cut thin plate steel. HELL NO! Just because it can, doesn’t mean we should.
If I wouldn’t get so much back lash I wouldn’t allow plastic either. I have had to pull off melted acrylic from inside the table saw, band saw and dust collection chute a few times. I also don’t like it when people use the sanders on plastic. It melts and then ruins the sand paper.
I understand most of the time it’s because most people don’t know any better. I have done things in retrospect were dumb as well. I was the one that tried to bend metal rods with the metal brake and ended up marring the edge. It bent my rods but left the metal brake less than perfect. That was my ignorance. I told a few people and they rectified it. I won’t do it again and hope others will learn from that mistake as well.
Like I said before, I brought this post out of depths because I was PM’d asking if metal could be cut on the table saw and they referenced this post. I want all future readers to know that no metal should be cut in the wood shop. (minus the CNC when done properly).
Thanks,
Alex
