Was up yesterday evening and night and did a lot of work on it. On the way I stopped off at Taco Hut and picked up an assortment of street tacos and shared them with @Ebony_Jackson who said she never had them before.
I wanted to repair some broken parts on the plastics (which are unobtanium, but that’s a different story) so I started off by taking the upper and side plastics off then pulling the upper playfield off the machine.
In this pic you can see the duct tape on the ramp on the left and all of the dirt around the upper kick hole. The whole playfield is covered in plastic so I took it off and cleaned and waxed the underside of the plastic and the playfield. It looks MUCH better than this pic now…
This pic shows one of the holes to fix. Fortunately, the plastic pieces were in the bottom of the cabinet, but, it needed some reinforcements behind it so I had to fabricate those.
This one shows a cracked area that didn’t break all the way. I had to clean it, use some accelerant on it, then glue it back together. It needed reinforcement too.
With the duct tape off you can see the big section of missing plastic. Luckily the pieces for this were almost fully in the bottom of the cab. It was missing just a small sliver at the bend in the plastics. These pieces were glued back in, but it too needed reinforcing.
This piece is on the upper ramp section that sits on top of the upper playfield. It has a hole in it too, but I don’t have all the plastic pieces to repair it. It has a piece of very thick clear tape over it thanks to the previous owner. It’s going to stay like this for now.
@Shawn_Christian went with Ebony to Home Debit pick up a new tool box for Vector and while he was there, he picked up some plastic sheeting for me. This is the raw material I used to build the reinforcements for the high stress area of the plastics.
I used one of the 10x10 art squares sitting in Vector, a square, a chisel from the machine shop, and a piece of duct work from the foundry area (PERFECT circumference!) along with a bit of work with a band saw, coping saw, and a Dremel, to fabricate and bend the plastic into the proper shape. This took some time and patience, but the results looked great!
This is the test fit after I got all the bends done and the edge cut to keep it from sticking out beyond the edge of the playfield. Normally I’d like to bend it over that edge and use a couple of screws for strength, but that edge sits up against the back of the pinball cabinet so there’s no room.
To be continued…
