Are any of our expert wood turners available to teach a class in how to safely cut and prepare logs as bowl blanks?
This would ideally show how to use a sled, and how to clean the bandsaw blade if sap gets on it so it cuts cleanly, doesn’t shred wood, and keeps the blade useable. Students should all get hands-on experience, and a blank to take home with them.
@skeeter kindly cleaned up a mess on the Laguna bandsaw from someone who was most likely unfamiliar with the right way to prep blanks.
If ever a class deserved an honorarium for preventing accidents and tool damage, it’s this one.
Expert might be stretching it a bit, but I can do a class on this. Does @Team_Woodshop or anyone know the status of the electric shop chainsaw? Its been a couple years since I used it and I recall that the auto oiler was not working correctly and it was butter knife sharp. I can grab a chain for the class and bring oil if that is still the case. I would plan to structure the class like this…
selecting wood for bowls, grain direction, planning the cut, etc.
General chainsaw safety
breaking down a log with the electric chainsaw - outdoors
marking and cutting out the bowl blank on the bandsaw
cleaning the bandsaw and blade of debris after cutting
how to mount a bowl blank 3 ways (between centers, screw chuck, waste block)
if time allows we can go over the sled, but bowl sized wood is better cut with a chainsaw to get a flat surface before it goes to the bandsaw. But small bowl blanks and other small work can be done on the sled.
Some of us don’t/can’t use chain saws, and the main goal of this for me is to prevent bandsaw-related accidents and breakage. Would you consider doing both, especially if the chain saw won’t always be properly maintained?
I think the sled is important, and I would prioritize that over mounting the blank on the lathe, because I believe that’s part if the bowl turning class.
Sure! I think @Holliday is right. We should do a chainsaw class and a bandsaw class separately. Im pretty comfortable on the bandsaw but would want to research / build some better jigs before doing a class. There are some jigs that use the miter slot that seem better suited for larger logs.
I think a class covering blade changes, general maintenance, using the correct setup for large and small round pieces, and cleanup would be a good one. I’ll look into getting some things made / learned and set something up for both classes.
