And if you follow the 3d fab committe hangouts it aapears that all too few actually pay for their use.
This is currently reflected in the diminished supply of filament.
Stan, (and everyone else)
I never said an hourly rate - I just believe that someone who ties up a lift for 2 days should pay more than someone who uses it for 2 hours. I think Doug is on the right track with a Parking Garage type sliding system.
Also, I have never used a lift for a brake job (okay, I know it was an example)
Put a QR code on it so itâs a smartphone / paypal direct to Auto. (assuming thereâs a mechanism for that. I know it works in 3D printing. )
Thatâs a cool idea, Todd!
Walter, I am aware of the shortfall in 3D. (it is easier to fudge on material measured in grams than on time spent in hours) I didnât say it was perfect and an acceptable solution will probably have to be converged on with time.
To use one of your sayings, we may have to sneak up on an accurate measurement.
JAG âThis Has Been A Test of the Emergency Discussion Systemâ MAN
I think the $100 training is a great idea. It will help cover the costs of installing it and the electrical work plus the reasons you already mentioned.
$100 is nothing to many of us⊠However, it stands in stark contradiction to what DMS is suppose to be about. Therefore, I strongly disagree with the concept. Also, $100.00 is a lot of money for some. AND it will not necessarily discourage the one time âmembers.â
There are distinct issues at play here, however we are mixing them as if they where the same in our conversational Van Diagram(Pun clearly intended.) In essence we are not speaking with the same dictionary.
The issues, which are separate and distinct that must be addressed are:
One time Hit and quit âmEmBeRsâ which are conducive to abusing DMS and degrading the DMS culture as a whole. Wholly undesirable individuals.
Lack-Safety~Abuse, that such membership would create and the problems they would bring.
Cost of use for the equipment-time, to ensure availability, discourage abuse.
Training, an obviously Safety centric item that MUST be Required as it will reduce risk, liability and (realistically) injuries. Equipment Lifts are comparable to hammers, They are only as good as the operator, and a bad operator can cause SBI/Death to themselves/others easily.
Culture of DMS⊠As most of the Solutions offered above change the Culture and they are hardly to be considered being âExcellentâ to each other or DMS.
Since all this issues are related and loosely intertwined they are becoming confused. Whatever measure we employ, we must be cautious that we do not create unintended consequences.
Therefore - The easiest way to benignly address all of these, with out creating further issues, is to require multiple part training. Training to be offered once a month, and testing for said training offered the subsequent month.
Each session Should be started by TESTING everyone who is trained first⊠then, those that failed the test, or have not taken the training class can stay for the Training session. This insures that there is a two month window before anyone can use the lift.
This should also be an oportunity to introduce, formally, those trainees to the AUTOMOTIVE Shop, with testable knowledge. Such as what to do after an oil-spill at the space, where does the use oil go, What do we do with if our inoperable vehicle must be left overnight; how does one move an inoperable vehicle down the ramp?!? Etc.
I am working/researching on a way to inexpensively use the RFID tags to unlock and log equipment use. Until such a system is operational, it will be difficult and impractical to ENFORCE any type of pay-per-use or any other time management scheme. As an example of what I am referring to: We routinely have non members at the space, for starters. That thread is up to 43 post, and counting.
âŠXâŠ
Yeah, you bring up a good point. If we can keep new members from voting until theyâve been here three months, whatâs to stop us from keeping someone from using the lift until theyâve been here three months? Maybe you donât have to take $100 out of someone all at once?
Now we are back to creating second class members who donât have full access to all the tools the first day they join.
And for what reason?
Safety?
There isnât a 3 month waiting list to use the table saw, band saw, metal lathe, welder, or other of the more dangerous tools. The training class on this lift shouldnât take more than a few minutes with a simple signoff sheet stating you have taken the class and know the risks.
Drive by membership?
There is way more chance that someone is going to join for one month to use the woodworking tools to build a bed, or patio furniture then quit, than there is going to be people lining up to use this lift.
I have to strongly disagree with this idea. Most people canât wait a full month to be able to use the lift for repairs/projects. Add in scheduling conflicts and it gets even worse.
The simple solution is to offer training to DMS members only for a nominal fee ($50 max) and feel things out to see how it goes. If it becomes clear that people are joining for a month just to use the lift, then we decide how to address the issue.
Obviously, the lift needs to be locked out with keys provided to those with training.
I frankly feel like an oil change would tie up the lift unnecessarily. Itâs extremely easy to change oil on the floor with ramps.
I would like to see the lift âreservedâ for more complex work⊠but maybe thatâs because Iâm a regular user of the auto shop and I tend to spend a lot of time rolling around under my Suburban.
RFID tags can do this, without having to issue physical keys. Need some readers with solid-state relays on a timer at the device. Tap your tag, SSR engages on a timer, allows the lift to run for 15-30 minutes. Another tag tap is needed to reactivate.
Instead of trying to homebrew this, why not just see if Ops can allocate funds to all âpower toolsâ for this sort of hardware? We need it now, and the homebrew solutions donât seem to be making forward progress.
(Being a embedded firmware/systems geek, Iâm having trouble recommending a commercial solution, but I think we need something now ⊠not another maker project)
It looks like you folks are overthinking the use of the lift to an extreme .
Awsomer - I donât think it is reasonable at all to have to wait three months to use the lift by anybody.
It is NOT a CNC or other delicate machine - the lift âtrainingâ couldnât possible exceed 15 or 20 minutes to anyone cable of filling out the waiver when joining the DMS.
Brandonâs fee is a bit excessive I agree - Iâd suggest $50 as a one time free to members.
Zero vehicles left on the lift overnight / in excess of a single 24 hour period should be a rule. If a car is left on the left over the time then that member should forfeit use of the lift for say 30 days.
Letâs be reasonable & friendly here and keep it a dot.org oranization.
Iâm a new member (july 14th) and donated it in the hopes of giving back to the DMS for being an enjoyable space to be. So far it has been a great experience.
The motor and pump unit along with the misc other items will be brought in Fri or Sat depending on my work shedule - the motor is SINGLE PHASE.
What does it take to get on the automotive commitee?
Tom,
Heh, heh⊠agreed.
It may help to understand a few things about DMS and our culture:
Fundraising for installing 2 post lift )
and interestingly it was Ken Purcell who made the original $100 suggestion for training and he is the Electronics Chairperson. (very nice guy and has done great things for that area) Also, Brandon made a very good suggestion regarding the training fee. (you can review the thread if you like)
The real danger is in taking ourselves too seriously or getting overly rigid / entrenched in being right or whatever, though the safety aspect should always be paramount.
Letâs be reasonable & friendly here and keep it a dot.org oranization. Iâm a new member (july 14th) and donated it in the hopes of giving back to the DMS for being an enjoyable space to be. So far it has been a great experience.
Good points - I think it best to show mindful appreciation for this gift and discuss this a bit more calmly. In my world view, the Universe tends to send more good things when you take this approach.
Ironically, there seemed to be less conflict when we were considering buying the lift outright instead of having a benefactor like Tom appear. (compare the threads and decide for yourselves)
Sounds reasonable.
Tom, if you go to the Wiki here:
https://dallasmakerspace.org/wiki/Automotive_Committee
It states under the Members section:
âBrandon Green is currently the Chair of this committee. No formal joining of the committee is required, any members is free to help with any projects or use our available tools (in accordance to the rules).â
Tap your tag, SSR engages on a timer, allows the lift to run for 15-30 minutes. Another tag tap is >needed to reactivate.
I believe from a safety perspective, this might be undesirable if you need to adjust in an emergency. Also, one more layer adds a potential fault point.
Jeremy, I agree, my Jedi mechanic.
I personally would not use it for that either, but some members have physical limitations and may not be able to scooch under or work underneath on their back as ably as you and I.
In retrospect, it was probably not the best example, but the point was quicker, âlight-lineâ work as opposed to the more complex projects you mentioned. And sometimes it is desirable to lift a vehicle just to get a visual recon of the suspension, motor mounts, underbody damage, fluid leaks, etc.
Oh, and something else that occurred is a central philosophy that Stan brought up about rushing through a job. I learned a long time ago that short cuts are expensive with a lot of things, particularly with auto repair. In general, the difference spent in time between doing a hurried, sloppy fix and doing it correctly and methodically is only about 10 minutes on average, so it is better to develop professional habits and keep learning from others.
If you think Iâm wrong, then do something rushed and half-assed, then find out how much more time and money you have to spend correcting that mistake later.
JAG âThe Zen of X-Wing Maintenanceâ MAN
Find me something I have been looking for something for years!
If I was doing it, the tag swipe would unlock the power, but that power wouldnât be shut off until the lift was back down. Perhaps a toggle so that the lift automatically goes off when it hits bottom and would then require a tag swipe to get it back up. It could then track âtime upâ for each user. Simplest may be to have the tag swipe trigger a physical lock on the lift, similar but opposite to the automatic locks on some jacks. The relay pulls a sloped/sprung pin from the body, so the lift can go up. When the lift goes up beyond an inch or so, the pin is reengaged automatically, but the hole no longer lines up, so it doesnât lock anything. The body coming back down automatically engages the pin as soon as the hole lines up. That way, your tag swipe relay isnât even tied in to the 220v power system or whatever, it is tied to a separate power source and only has to control the lock pin.
Of course, there are always exceptions.
Another suggestion is to post a big sign on the lift with the cost of training. Reason being: there are DIY garages in DFW that allow people to pay a rental fee for using a lift and tools. If someone has a single project that they want to work on and, during the tour, they see that the âjoin for one month just to use the liftâ method isnât necessarily more cost-effective than one of those DIY garages, it may curtail some of that behavior.
My 2 cents, this is.
Iâve noticed any time the idea of having RFID locks on the equipment is brought up that there are concerns about safetyâprimarily that time-outs can be hazardous when used with heavy machinery, as well as issues with hacking a relay into multi-phase non-standard power setups.
I was wondering, what about instead of RFID locking the equipment directly, we had manual locks over the power switches and the keys for all such equipment kept in a grid of small electronic lock boxes? RFID a console (maybe similar to the one in the kitchen?) and choose what tool(s) you need. If youâre on a list of approved users for that tool, it can pop the door open for you. No worry about timing out of equipment when you use it, we can still track what is being used, when and by who, and no need for an employee to check out equipment for usage. Could also be used by other committees like Digital Media with slightly larger boxes to house their nice digital camera for check-out.
I guess the only question would be, would people actually return the keys when they were done?
As to the lift, $100 seems pricey, though Iâd likely pay it (Iâm staring at a need to swap out a $20 part that would otherwise cost near $1000 to have it professionally done, due to the need to access the transmission). Personally Iâd much rather see it at $50-75, but thatâs just me. The 3 month waiting idea seems ludicrously unnecessary though.
âI frankly feel like an oil change would tie up the lift unnecessarily.â I suppose this is technically true, but it would tie up the lift for all of 20 minutes. I donât know exactly how much use the lift will end up getting with all the stipulations developing around its use, but I would see nothing wrong with a frivolous lift for an easy oil/brake change/tire rotation if it was being otherwise unused.
Shaun,
usage.
That is exactly what I was thinking over breakfast this morning - RFID the control key, not the machine.
Thought about that too and I may have an idea. Attach a light, but large and brightly colored block to the key so that it is easy to spot and difficult to walk out with in your pocket without being aware of it. In addition, put one of those finder RFID tracking devices or a Tile on it so it can be located easily. And have an emergency set of spare keys.
Does anyone know if these things work well or not?
JAG âDowsing For My Car Keysâ MAN
Again, maybe the best solution is to start with fewer rules and change if necessary.
Itâs kinda silly to sit around and theorize about future problems that may or may not arise.
Jeremy,
Again, maybe the best solution is to start with fewer rules and change if necessary. Itâs kinda silly to sit around and theorize about future problems that may or may not arise.
Agreed on that as well. Letâs not live in what one of my friends has aptly named âIf Landâ - just get it going, focus on safety and see what sticks to the wall, then deal with the issues that actually do arise.
JAG âTriage Of Attentionâ MAN
Haaa, I love getting called out on the $100 fee, yes I did propose it initially. But I was trying to get the money to BUY a lift. Now we have one donated. Maybe $100 training fee is appropriate or not. People will with vote with their dollars.
I propose a $5 per use toilet fee to replace the broken toilet tank lid.
truly sorry for saying that
On another note it does seem we have moved the deep discussions to talk. Instead of the membership meetings where we hashed these kind of things in detail in the past.
We are perpetually looking for an equipment access system. Each device has itâs own particular challenges. Canât cut power in the middle of a cut, shouldnât lock out the lift if it needs to be moved in an emergency since it is resting on someoneâs chest, etc.
I am currently searching for such an option. There are a few viable commercial solutions, but they want to tie up the hardware with contract maintenance. Those that do not follow that business plan seem to be clunkly or prohibitively expensive. The search continues⊠Thus if you have any suggestions, please let (M̶e̶) us know.
âŠXâŠ
