…Y’all need a proofreader on that learn.dallasmakerspace.org polyprinter class.
The info in the course doesn’t match the quiz. The grammar in the rules section is so bad it’s difficult to understand. I tried to document as many of the issues as I could, and where the conflicts were located to make it easy for the mod to fix the class/quiz. I know we’re all crunched for time.
Quiz
There are major information inconsistencies in the class/quiz. 4/19 questions have issues.
Q. How many PolyPrinters are you allowed to use at a time?
–Correct’ answer is 1. This directly conflicts with documentation.
Rules Page: Rule#4.
“Users can use multiple printers, as long as there is at least one printer left available for others to use”
in conflict with:
Loading Filament page
" We only allow a member to use one machine at a time." (directly under pic of polyprinter)
Q. Who is authorized to repair the polyprinters?
– ‘correct’ answer is ‘polyprinter employees’
conflicts with documentation presented twice in the learning materials.
Pg1. Rules:
- NO PRINTER MAINTENANCE unless Authorized by the chair or vice chair
AND
Safety page:
If the nozzle clogs, you won’t be able to extrude or push plastic through the hotend and your prints can stop and fail. The nozzle will need to be replaced by a Polyprinter employee, chairperson, or vice-chairperson.
Q11: What program do you use to prepare the file to print
Unclear: Slice or load to polyprinter?? Either could be considered ‘preparing’
Q14: Spelling test, not knowledge test:
‘Thingaverse vs thingiverse’ Quiz questions should test the points you most want users to remember. This question just tests users ability to spell.
GEN GRAMMAR:
Page 1: Rules:
Your VS You’re errors. Gross grammatical errors.
“Place contact information on top of printers (yes even if your 2 feet away)”
-YOU’RE 2 feet away -
“After an hour of job completion another user can remove your print.”
-consider using: “If your print is left for longer than an hour, another user may remove your print”
