So, quick follow-up on this.
I became curious on doing smaller cuts for multicolored designs and in my research I found out about the adhesive cutting mats that are used by cricut and cameo.
At that point I started getting curious as to whether or not it would work with a US Cutter Style machine like the Titan 28 or my MH 871.
So, I went and got one. I found it at Aviva in the Sam Moon shopping center for $19.
My theory is that using the Easy Cut Pro, (Vinyl Master should work the same), I can separate by color and use smaller pieces to cut out what I need as long as I use a very, very low cut speed.
I’ll be messing with this some this weekend. As soon as i have some definitive information, I’ll update.
I’m hoping that I can get the finer details with smaller pieces of vinyl, well see.
More to come.
