Lasersaur is tired
I used the lasersaur last night and the poor girl is tired. I was cutting 1/4 inch acrylic and had to set the cut speed a snail and the power at max. It took me 6 minutes to make my cut once, on the thunder laser I was able to make the same cut cleaner in 1 minute.
Might be dirty optics or time to replace laser tube.
@laser_committee, What is our next step?
I think an incorrect focus block keeps getting into use, and probably an alignment check would make sense.
I used the White t shaped focus block, is this now incorrect?
Not sure, at least that is not the one I knew was suspect.
I think the tube was a dud. It measures at half it’s rated power and that was months ago. Laser committee has money to order a new tube. @PearceDunlap, want me to order a new tube and expense it to laser committee?
Thanks @lukeiamyourfather,
@dr_cee had a similar feeling last night.
