I need to staple some elastic bands to the back of 1/4" hardwood plywood. The shortest staples I can get have 1/4" legs and unfortunately they are ‘telegraphing’ through the surface veneer layer - meaning they don’t penetrate but are raising that veneer layer slightly.
I don’t have the option of doubling up the elastic, which does fix the problem. What I’d like to do is find some flexible plastic that the staples will penetrate to add a little thickness and prevent overpenetration. I figure about 1/32 - 3/64" thick will probably do it. I need to make a bunch of these so would like to laser them.
Can someone suggest a laser-safe flexible plastic that might work for this application?
