Hi! I know vinyl is on the no lasering list, but is Laser safe heat transfer vinyl on the epilog ok? It’s made completely free of PVC and has been tested, and epilog even has a tutorial for it. Its Siser Easy weed. Laser Engraving PVC-Free Heat Transfer Material
I’m not on the laser committee but I’d think that if it’s specifically laser-safe and Epilog agrees, have at it. Just make sure you didn’t buy Chinese counterfeit material that isn’t actually safe.
Chlorine is the concern. If there’s no PVC and it’s obvious, like it’s on the package, then it’s fine. Probably keep the package in case people ask or have concerns while you’re using the machines.
also do a test cut and see if it makes a lot of really sooty smoke or ash. if it does it’s best to reevaluate if it’s good for the laser
