Laser Printer Available for Members?
Do we have a Laser Printer available for use anymore? I found a thread hinting that we might, but there was never a definitive answer. IF we have one, where is it?
The copier that sits in the hallway outside of the Interactive Classroom is a laser printer and available on the network at DMS.
Awesome, thank you for the info!
There is also one in the common room at the end of one of the tables. I believe you can plug it into your notebook or pc via USB. I’m not certain if the network has been setup or not.
Cool. Ordering some weatherproof laser printer labels now. Thanks!
The HP laser printer in the Common Room is B&W only. Yes it can be used via the nerwork, the IP Address is located on the front of the printer. You can also use the USB cable that is attached to the printer to coonect to other devices. The Print Drivers are online, HP carries all the drivers.
The big Samsung X7600 color copier/printer has been moved from next to interactive to the common room next to the server room. Everything works the same, it just has a new place to live.
In light of the fact that the Bookkeeper has also moved, should the Finance collection box be moved into the new Common room?
Yes, but it will have to be moved when she is here… She has the key to open it, and it has to be opened to be cleanly removed from the wall.
Having trouble with the web print option.
I’m not sure what you mean by “webprint”. However if that is a different way of referencing the connection via the WiFi network, my experience is this:
Do NOT choose the “Samsung blah-blah-blah” option from the list of available printers. Your job will just hover around in hyperspace.
Choose the one that is a string of numbers (up address?). Then it should work for you.
