Laser Material Check
I have a 60% rayon 40% wool blend felt with an acrylic-based adhesive backing. I was wondering if this is ok to cut on the lasers? I know that wool and rayon are ok but is the adhesive backing a problem or should it be ok? Thanks in advance for the insight!
It should not be a problem for the laser material wise. I am curious about the results, wondering how the Rayon and the Wool react together.
For my own personal gratification, what material is it called?
I think it’s just called “wool blend felt”.
Here’s an example.
Yes it is just wool/rayon blend felt. Here is the link to where I got it. McMaster is great for finding specific materials. McMaster-Carr
I will post pictures after I do the cuts to let y’all know how they turned out.
If your parts are small, consider leaving tabs to connect them to the main sheet, so they don’t blow away while you’re cutting them.
