I have some thick cast acrylic scraps with lots of usable area. Some of the thicker stuff is between 0.5" - 1".
At what thickness does it become difficult to cut this with the 130W Thunder? Any recommended techniques beyond those in the following links? For some cuts I’m not concerned about maintaining the polished edge look.
Seems like the major point to getting a good cut is to adjust the focus at a distance midway into the material.
At what thickness can the Thunder make a ‘clean’ cut in a single pass. Is an acrylic cut still relatively smooth (no steps for each cut pass) if multiple passes are needed?
How much does the kerf width change as a function of depth?
If it changes, then the edges won’t be at a right angle to the face. The context is laser cutting faces of an acrylic, then gluing them together. Ideally the edges should be fully touching the face when bonding using acrylic cement.
