I think i may have found a reason why we’ve been burning up bandsaw blades on the laguna. I was resawing when i started to see sparks flying from the upper bearing support so i shut down and assessed. The back of the blade has cut a groove into both the bearing and the support bracket (see pics). I readjusted the bearing so its not in its self-made groove and so the blade is father away from the bracket. Afterward, blade ran smoother and presumably cooler. We should replace that bearing at some point though.
edit: @Team_Woodshop
