I took the plasma cutting class the other night and I’ve designed a knife or two I plan to cut from some steel I have. Is there any training on the KMG-10 Grinder before I use it to grind the knife edge?
There is training required for the KMG grinder. I will be at the space this evening I can help you out with that if you want.
What time do you plan to be there? I’m retired so I can meet you pretty much anytime but I’d like to come after dinner if possible. Also, how long does the training normally take?
I appreciate very much your willingness to teach me.
I should be there around 6:00 it should only take about 15 minutes.
If 6:00PM works for you I’ll see you then. Should we meet next to the grinder? I’m a tall guy so if shouldn’t be hard to spot me.
Works for me I’m a redhead can’t miss me
See you then.
Sorry I’m running about 30 minutes late. Be there asap
Ok. See you when you get here
How far out are you?
Thank you Joe for the 1-1 training.
Any time glad to help
