Hi, I had two bowls that are a set that were on the glaze shelf together. I checked today and it looks like one is currently being fired but without the other. I didn’t think about the possibility of them being fired separately so I didn’t put a note but these two are very much meant to match so I’m hoping to find out which kiln the first one went into(loaded in the last 48 hours) and how to ensure the second goes through the same firing. I know the kilns can differ quite a bit.
Adding a picture of the bowls. I also put a note in the remaining bowl basically stating the same thing, that they’re twins and need to be fired in the same kiln, fine with this second one waiting as long as needed to ensure the best chances of these matching so I don’t have to completely remake this set.
Thank you,
Audrey
