Blade snapped. Here’s why:
After a test cut, I noticed some bad wobbling and tracking issues. Opened up the machine, the tension gauge wasn’t installed right, just dangling, the blade was tracking way too forward, and the guide bearings were all off. Installed the gauge lever back, adjusted everything, turned it on- everything was centered and nice with proper tension.
I was alone, so I left it on while putting the allen key away, that’s when the thrust bearing guard plate fell into the blade and snapped it. There are supposed to be two screws holding it in place, but there was only one and its threads are completely stripped. It’s just hanging there and not secured at all. Those holes need to be retapped.
I’m leaving the guard plate off. It’s more dangerous to have it hanging like that.
TL;DR Little screw causes big problem.
