I didn’t say band saws weren’t useful or anything about replacing existing bandsaws. I was replying to this:
Is replacing both cold saws with a horizontal bandsaw w/ auto downfeed on the table?
Cold Cut (CCS), Vertical Band Saw (VBS) and Horizontal Band Saw (HBS) all have strengths and weaknesses.
Companies that do a lot of heavy cutting, especially of heavier thicker material, use CCS type saws, they fast, have excellent blade life, and the coolant flooding keeps the blade lubricated and cool as well as the material. Large high speed band saws also use coolant flooding.
You really can’t compare the time it takes to cut material on a VBS/HBS vs CCS. Band saws have advantages over cold cut saws and vice versa.
- Band saws can cut THICKER materials, theoretically limited to the gap between table and how high the blade will go. (as a practical matter probably about 4" if a solid bar stock on how sized machines)
- VBS’s are limited to the throat depth for how LONG the two pieces can be.
- CCS and HBS saws can cut any length of material up to max thickness limited only by space on either side of the vise. E.g. CCS/VBS can cut a 4" piece of solid bar stock 20’ in half, 10" on either side, a VBS can cut a 20’ piece into two pieces but one piece limited to throat depth - say 24"
- VBS can cut curves, HBS and CC cannot. Material size is pretty much limited to what you can hold. VBS typically do not have out feed roller tables.
DMS is fortunate that we have all three. I’ve cut steel blanks for classes. It took about 90 minutes to cut 8 pieces on the HBS, about about 15 minutes on the CCS. With a better cut finish.
