ISSUE: Plasma cam not completing initialization
When I initialize the cutter raises and moves to the home position but the pop up window on screen doesn’t go away like it normally does after any movement. You can hear the motors humming until you cancel. You can’t use the jog on the controller but you can use the dial to move. Just hangs when you send to cut.
Checked all wiring, rebooted all devices.
I assume a computer restart didn’t help either?
So it appears to be good now. We reset factory defaults.
