Does the DMS or a member have an iPad 2 (specifically) that still works? I need to borrow one for less than 24 hours to test some equipment and need this exact iPad model.
I’ll check at home. I think my wife’s old iPad is an iPad2. I’ll check when I get home tonight.
There’s one on ebay going for under $40:
I could order it and have it available as part of the interactive computer museum.
I’m not sure it’s what you’re looking for, but I have an iPad A1430 you can use if needed. It’s coming up as iPad 3rd Gen circa 2012. Has the old 30 pin port.
That may work! I just need the 30pin connector, and the one with the rounded beveled edge with same body shape of the iPad2. So, not the square one. Is this the one?
I finally found my wife’s old iPad. When will you be at the 'Space next. I can try to meet you with it.
