ISO: 30" wood round
I’m looking for someone who can cut a 30" round out of 1/2" birch (or similar quality). I have the ability to do it myself, but not the confidence to get it right the first time! I understand that size is a bit expensive. Let me know!
How perfect does it need to be?
Fairly perfect. It’s for a customer order for a sign. Unless it’s something that can be covered with paint or patched with filler.
https://www.amazon.com/s?k=30+inch+round+wood+blank&crid=31I7XEKUYTBRG&sprefix=30+inch+round+wood+bla%2Caps%2C585&ref=nb_sb_noss_2
These blanks are made by the hundreds, take advantage of the very low prices…
Do you have the wood?
Using the cnc will take some time for setup but it will be a perfect circle.
Using the bandsaw will be quick but it will not be perfect. Can get it very close.
Sorry, I should have put that in the post. I don’t have the wood. I was hoping to find someone that has it on hand otherwise I’m stuck buying a full 4x8 sheet with leftovers I won’t use. (Unless you know of a place that sells 3x3 sheets at a decent price? I’m not super familiar with lumberyards, only HD and Lowes.)
Thanks, I’ll look into it! I figured shipping on something like that would be outrageous but maybe not.
Does it have to be exactly 30"? Rockler sells a 30" square piece for $34.
If, on the other hand, you need it to be exactly 30" then you’d be better off buying the $60 item on Amazon because you’re going to pay more than that for a piece that’s bigger than you need. The link Burt @swa provided has free shipping.
Yes, it has to be 30" and I just ordered one from Amazon. Thanks everyone!
