I’m trying to make a piece as wall art and want to use the CNC to cut out a geometric design.
Can I buy a piece of wood at this size or will I have to glue a few slabs to make a 3 ft square? Also, which wood would be best to keep it light so I can hang it on a wall?
3/4" is common but I understand it’s difficult to get in 1" thick. You could “laminate” two 1/2" pieces together. It comes in 5’ x 5’ as a common size and I’m guessing 4’x4’ also.
There is a good weight calculator here:
It includes many types of plywood and lots of different solid woods. Note that the plywood comparison is 1/2" thick.
We have a laser with a bed that big. Challenge is going to be thickness. The laser gives a conical cut. You could cut identical 1/4" sheets and then stack/glue them after cutting. You could use 1/4" ply as the back, saving some weight.
[EDIT: Ask the laser experts … you might want to focus the laser partway through the depth to get the best cut on something thick]
The Tools page of the wiki is a good overview that points you to specifications and information about most, if not all, of the major tools that we own.
It is linked from the upper RH corner of the main wiki page.
I carved these three pieces on our CNC, using 1/2" plywood. It’s funny you should show the design above, because that design was what inspired these three.
