Hey all, I am getting an internal error when I try to sign up for this class:
https://calendar.dallasmakerspace.org/events/view/19482
Is anyone else having this problem? Does someone know how to fix it?
You are a member, yes?
Hi, it looks like your registration did go through I think.
Did you get the error when clicking the button, or after filling out your information? Did you try again and then have it work or was it still erroring?
Yes I am, but I did join just this month.
This was after I filled out my info, and repeat tries yielded the same result.
That doesn’t matter. You could have joined today. I was just wondered if you had logged into the Calendar. However, Josh says that he can see your registration for the class, so it sounds like you’re good to go.
So it looks like you have a current registration for that event, but as a guest not as a member. My guess is the reason it’s not letting you sign up/ it’s erroring is because a registration already exists with that information. (Which means that I need to fix the errors on the calendar a little bit better )
Gotcha. Thanks for your help everyone.
I had those errors but it did show me as registered as well.
