That would be far too frequent. Once a month is probably plenty. We’ve got a nice big bucket, and folks aren’t supposed to be dumping actual chunks of clay down the drain.
Hi, I heard from a member that the clay trap maybe leaking. Heard that the wing nuts may not be tight or the bag could have a wrinkle along the rim. I won’t be in until later in the day on Friday. Could someone there in the morning please check this out for us.
The other day I saw a lady cleaning ceramic brushes in the sink of the Galley. I explained to her that that she should be using the janitors closet because it is the only sink with a clay trap. She just kept on cleaning her brushes. I do not remember who this was. Your Ceramics folks definitely need to be re-trained.
If it is indeed leaking, there are a couple of likely culprit issues that are super speedy quick to fix. No big deal. If there is a leak rather than a slow drying messy spill, it is likely either the wing nuts not tightened down enough or, more likely, a small fold in the bag along the rim. It has to be perfectly smooth or it creates a channel that leaks once there is pressure.
Rich, if you see her again or recognize her please let us know. We focus on cleanup procedures in our 100 class and specifically talk about the utility sink and the clay trap. We can continue to point people in the right direction and reinforce our procedures when we see things like this.
Disposable bags are in the brown mailing tube. Tube is labeled and most likely in the top rightmost wall cabinet shelf but I retain the right he be wrong about that.
